Home > Maintenance & Mods (L322) > Water draining from upper tailgate.
Range Rover L322
After it has rained when I open the upper tailgate a stream of water pours out of the tailgate left hand side - about a small cupful which goes down the left side boot cut out - at least it's not inside!!.
The drain holes at the bottom are clear on both sides.
Any ideas?
Post #529914 2nd Oct 2019 11:00pm
Fox889
Funny you say that, mine does exactly the same, be interested to hear what others say. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #529918 3rd Oct 2019 3:49am
mercs600
England 2002 Range Rover Vogue Td6 Java Black
And mine , thinking about drilling extra drain holes.
Post #529920 3rd Oct 2019 6:07am
kooky_guy
And mine. Often more than a cupful though! 2010 4.4 TDV8 Vogue SE
Post #529921 3rd Oct 2019 6:39am
8810bigcat
Ditto, just had the side trims along the glass on the upper tailgate replaced as had started degrading on the left side, which I think was the result of this. I think, as the above posts suggest, is a common issue. RR Vogue TDV8 Grey/Black
D3 TDV6 HSE Silver/Black (Gone)
D3 TDV6 HSE Black/Tan (Gone)
RRS TDV8 Black/Black (Gone)
RRS TDV8 Stornaway (Gone)
RR Vogue TDV8 (Gone)
RRS 4.4V8 (Gone)
Defender 110 300tdi (Stolen, much missed)
RR Vogue V8 P38 (Gone)
LR 90 TD (Gone)
Post #529951 3rd Oct 2019 2:15pm
Fox889
Have notice that the two glass rubber seals are somewhat loose as if they've been constantly nudged while washing. Is there a way of sealing them back in or a simple job to replace?
Still can't get my head around when you raise the tailgate where the water has been sitting and where it goes when you lift the tailgate?
How does the water enter the tailgate, there's no water leaking inside the car just a whoosh when you lift the tailgate. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #530000 4th Oct 2019 1:37am
Anvil
Me too..... I'll be watching this one with interest!
Post #530018 4th Oct 2019 9:50am
mercs600
As I mentioned above ,I get this and mine is a 2002 model and does not have the rubber strips. Think therefore that this rules out them being a problem on the later vehicles .
Post #530026 4th Oct 2019 12:28pm
mjdronfield
All the rubber strips do is stop the water from a wet window, dribble on the parcel shelt when you open the tailgate.
Not there to stop water entering top tailgate..... they all seem to do it.
I make sure I open mine after washing and let the water dribble out.
Not great is it!
Big Cry 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #530052 4th Oct 2019 4:51pm
8810bigcat
Re the rubber strips, I had them replaced by a specialist when in for a service. I don't think its a complex job although you need to be careful not to damage the glass.The specialist charged £50 labour and the parts were £55 so not a big job but does look better now. RR Vogue TDV8 Grey/Black
RRS 4.4V8 (Gone)
LR 90 TD (Gone)
Post #530225 7th Oct 2019 7:49am
Anvil
So basically all we can do is rust proof the tailgate and put up with it......?
Evil or Very Mad
Post #530232 7th Oct 2019 10:21am
pawsinmud
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
My car is 2011 and has rubber strips down the sides of the glass. This directs the water over the metal part of the tailgate when you open it so it doesn't drip all over the lower tailgate. I looked at a 2006 car and it did not have any strips at all down the sides, only the one along the bottom of the glass. Did they add them later and in which model year?
This thread seems to have developed into two water issues - the management of the water down the outside of the upper tailgate, hence my comments on the rubber strips, and the more important one of water seemingly inside the tailgate. My car has no water inside and surely none should have this, so there must be a leak somewhere, perhaps the bonding of the glass has failed, or has anyone taken the roof spoiler off to look underneath? 2011 TDV8 Vogue SE
Post #530245 7th Oct 2019 12:26pm
