Home > Maintenance & Mods (L322) > First time owner, want to refresh the car, looking for tips |
Walter Skinner Member Since: 02 Oct 2019 Location: Varna Posts: 60 |
Greetings! Long story short unintentionally I've purchased a LHD 2003 TD6 l322. I knew nothing about the car, well, at all, but I loved it from the first test drive, obviously.
2nd Oct 2019 10:01am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
Having been down a similar route I would not start throwing money at it, if it aint broke leave well alone. Having said that unless you know past history NUMBER ONE thing to do, Change the gearbox oil and filter. Then change the oil breather to vortex type. Remove the EGR and fit a Blank/ Bypass kit, Transfer box oil, front-rear diff oil. If the engine takes forever to get to operating temp check the EGR thermostat. 2007 TDV8 VSE
2nd Oct 2019 11:19am |
6 ltrs is enough for emptying the sump and changing the filter. You can flush the torque converter through the cooler lines to get more out. Someone posted only last week on how to do that. A BMW x5 e53 uses the same box so has the same gasket and filter. here is a link.. https://www.fullfatrr.com/forum/topic52923.html 2007 TDV8 VSE
3rd Oct 2019 1:14am |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
Like your car, this video is a bit clunky but given it is by the Car Wizard is worth a watch.
3rd Oct 2019 7:20pm |
Ok, I got your point. But there’s still a lot of those cars running nicely plus I’ve had a 2003 e53 x5 m57 before, so am familiar with the config. Unfortunately in two years I had no problems with it except died generator & pulley. Thats why basically I’ve started this thread: to get the list of stuff to change from more experienced members, replace everything & keep the car running for a couple more years. Worth to mention that m57 is the cheapest of all RR motors on the second hand market, you cant buy a v8 for £500.
4th Oct 2019 3:54am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Height sensor harness
4th Oct 2019 8:42am |
