Home > Technical (L405) > Not sure my air con is working?
Andy Cox
United Kingdom 2015 Range Rover Autobiography TDV6 Fuji White
I moved over to the 405 in the summer when I bought a 15 plate 3.0 AB with 30K on the clock, trading in my 2009 L322 in the process.
On the whole I love it but it has developed a couple of issues that I'd like to try and resolve without having to resort to the dealer and warranty.
Just recently, I've noticed the air from the vents isn't getting cold, even with the temp set to 'LOW' The fans pick up and it might get slightly cooler but not cold. If I turn it to 16 deg or above, the fans slow right down and it feels like it's just blowing air at ambient temp, about 18 degrees in the sun today. I'd expect to have to increase the temperature to something like 18-19 after a few minutes at 16 deg which I'm fairly sure is what was happening during July and August.
Am I correct in assuming that the temp selected on the dial should reflect the temp at the vents? Could this be a partially covered up cabin temp sensor?
Cheers
Andy
Post #529842 2nd Oct 2019 4:10pm
a/c button pressed? ... - .- -.
Post #529847 2nd Oct 2019 4:36pm
Andy Cox
i probably should have said that in my original post. Yes, A/C button - ON, Auto - ON. Even if I have 'MAX A/C' on, it doesn't make any difference. I've just been out to try it again there is no perceptible difference in air temp at the the centre vents between a selected temp of 16 to 26 deg.
Post #529854 2nd Oct 2019 5:30pm
see if switching auto off makes a difference...it could be that auto is thinking its cold enough not to reduce the temperature... ... - .- -.
Post #529861 2nd Oct 2019 6:01pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
regas i reckon, make sure you have the correct gas.
Post #529915 2nd Oct 2019 11:04pm
Andy Cox
Interesting idea Stan about it deliberately not reducing the temp due to Auto being selected. Will try that today.
Failing that, I will book it in with the dealer for them to look at.
Whilst it's there, I'll ask them to look at the infotainment system, which can take a considerable while to wake up and or switch promptly between rear view and main screen whilst manoeuvring. Is this something that others have experienced?
Andy
Post #529924 3rd Oct 2019 6:56am
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Andy Did you get anywhere with this? I have the same (not) cooling problem on my new-to-me FF.
Post #533154 4th Nov 2019 4:45pm
Gruute
Belgium
I thought that a differnce of 10°C (16 to 26) is not excecuted by the system. Can somebody confirm? 2017 Range Rover Vogue TDV8 silicon silver
2011 Defender 90 2.4 TDCI Nara Exclusive
2008 Porsche 911 997 4S Black/black
1970 Porsche 911T 2.2 in restauration
1980 Toyota Land Cruiser BJ40 concours winner
Post #533236 5th Nov 2019 4:53pm
Andy Cox
@nwmgc Sorry for the delay in get back to this, life's been a bit hectic lately.
Managed to get it back to the dealer last Saturday morning and had a helpful tech look at the issues I was complaining about which were: air con not cold, stop/start not working, delays/ freezing on the display and the tail gate not closing properly some of the time.
He quickly established the air con is not working at all. At it's coolest setting it's just blowing ambient air around. This may be why the start /stop function is inoperative. He said there is a link between the two systems, in that the cabin temperature will be prioritised over the stop /start function and if it's not achieving the desired cabin temp then the stop/start is disabled.
Hopefully the screen delay can be resolved with a software update and the lower tailgate needs a small adjustment to rectify.
It's booked in for a couple of days next week and I'm hoping this will all get resolved then and under warranty!
I'm surprised that a four year old car should need the air con re pressurising and wonder if this is a common problem?
Andy
Post #534248 14th Nov 2019 5:11pm
nwmgc
I should get mine back today. It seems it took some time to fix (three days) and I will find out more later. I do know there are problems with the new EU type A/C coolant fitted to our cars which is very leaky (as well as being much more expensive). I know that's what the initial diagnosis was - but will report back.
Post #534332 15th Nov 2019 10:03am
nwmgc
Well folks, it turns out it was the pesky-new-fangled-EU gas. The service adviser said 'the sales department have received a very large invoice'. I, of course, am relieved this is all under warranty but will be anxious that the stuff will seep away again. Still, something positive after five days with the stealer!
Post #534903 20th Nov 2019 3:26pm
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
Did you say the new R1234yf caused your air con problem ?
Just had mine regassed with this and two week later it’s not blowing cold ?
Post #669176 15th Jul 2023 12:46pm
nwmgc
Well, there was a lot more to the story since I wrote in 2019! It went back three times (pandemic didn’t help) over the next two years - even trying an even more useless dealer - and it turned out to be a pinhole leak in the compressor. Naturally, the dealer said it was a recent problem but it’s been fine since (touch wood and all that)… 🙄
Post #669181 15th Jul 2023 2:33pm
