Home > Maintenance & Mods (L322) > Changing trim |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1192 |
Hi, All as you can see the trim was looking a bit naff so ordered a new one from Dan Duckworths as you can see not as easy as I first thought getting it off was the easy part but getting the old glue from the car took about 45min, after picking off the heavy stuff I then used acetone ( nail varnish remover ) works great with other silicone products, ,sticking the new one just needed removing the backing tape and sticking it on.
27th Sep 2019 1:17pm |
Hi, Price from Duckworths £58 |
27th Sep 2019 7:04pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
Spray / soak the sticky tape in WD40. Leave it for 20 mins. Spray again. Leave for another 20 mins.
28th Sep 2019 6:09pm |
Thanks for the tip |
28th Sep 2019 6:25pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
absolutely grotesque for a strip of coloured plastic . |
28th Sep 2019 10:36pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Got mine off ebay 12mths ago, real stainless, steel, not plastic junk and only about £20.00,still pristine too. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
29th Sep 2019 2:14pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
29th Sep 2019 3:28pm |
found it.
30th Sep 2019 7:12am |
