Home > Technical (L405) > Off road suspensions
Statler
United Kingdom 2016 Range Rover Autobiography SDV8 Aleutian Silver
Every time I park and turn the ignition off the suspension sets itself to the off road height setting.
Anybody any idea either what is wrong or how to stop this please as it used to drop to the get out low setting.
Many thanks.
Post #529419 28th Sep 2019 6:09pm
if the 'access mode' is still selected then switch it off and see if that makes a difference.. ... - .- -.
Post #529436 28th Sep 2019 8:54pm
brad s1
2004 Range Rover HSE 4.4 V8 Giverny Green
not sure how much different the compressor is arranged vs the l322, but this used to happen in my 2009 when trying to drop to access height. The exhaust muffler was clogged from use so when it began to vent for a suspension drop, the existing air in the system couldn't leave, caused the thing to shoot up to off road height.
Again, not sure the system is the same or this is even your problem, but on the l322 the fix was drilling a small hole in the muffler or replacing it.
Post #529451 29th Sep 2019 4:34am
