Home > Technical (L322) > Starting up a diesel
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
One for the diesel owners....
When starting, do you turn the key to the on position and wait for the glowplug light to go out before turning over, or do you just go straight to turning over?
Reason for asking is I've noticed if I do the former, sometimes (a lot less often now with a new battery) I'll get a Special Programs Off ding when the engine fires, especially if the radio, lights and heater are all on at the time. If I just go straight to cranking the engine over, it doesn't happen. Seems like the few seconds waiting for the glowplug lights to go out causes enough of a drain to cause issues every once in a while.
And that's with a brand new battery, literally only a few weeks old. Was happening every time before the new battery, now it's a lot less but still happens occasionally, especially if the car has sat for a few days. I've taken to not waiting for the glowplug light now - am I damaging my plugs doing that? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #529326 27th Sep 2019 8:09pm
gettingold
I get the same if I also don’t use it for a few days. It’s the battery and if I use the car daily I don’t get the message. Nothing really to worry about but awareness these things like to be used and are heavily dependent on battery charge. I wait for the light to go out then turn the key. I also switch everything off until engine start.
Steve.
Post #529342 28th Sep 2019 5:45am
The only time I wait for the light to go out is on very cold days in winter otherwise I just start it as you would a petrol engine. Never had any problem, this applies to our other diesel cars as well.
Post #529350 28th Sep 2019 7:07am
dazza1983
I always turn the key / press the button to position 1 before starting and always have petrol or diesel. I like the idea the car gets a second to sort it’s electrics out before starting.
Having said that my glow plug light goes out so quick I hardly ever see it on lol. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #529530 29th Sep 2019 9:31pm
I just get in, put foot on clutch and press the button. I never switch it on then press for start.
So in that case the glow plugs heat up almost instantly. Under normal conditions the plugs aren't needed, its only when its very very cold that they are used.
Ive used the same process of jumping in and going on the coldest days we've had here no problems. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #529623 30th Sep 2019 8:10pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Always wait a few seconds once the ignition is on. Gives time for glow plug to heat up and more importantly allows electric fuel pumps to build fuel pressure 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #529633 30th Sep 2019 9:32pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Always give the system a few seconds to wake up and always let the glow plug light go out before starting . On mine if I don't let the car wake up it throws "u" faults up and needs to be cleared with the iid tool Thumbs Up
Post #529650 1st Oct 2019 7:08am
