![]() | Home > Maintenance & Mods (L322) > Looking for other suspension leak ideas. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2568 ![]() ![]() ![]() |
I would check the airline connection on the replaced strut after determining that the top nut is properly tight. |
Cheebs Member Since: 04 Jul 2017 Location: Georgia Posts: 18 ![]() ![]() ![]() |
Forgot about that part. When I first replaced the strut I didn’t tighten up that bolt enough. I went back in and a tightened it up and it held air until the valve block went. I did spray soapy water on the top bolt. 2006 Range Rover HSE |
Check/Test/Replace your height sensors .
so i found some issues. the front valve block i brought had a crack in the body. i replaced that. i replaced both front height sensors because the rubber on the joint of the longer arm was very floppy. i drove the truck around and watched my 4x4 screen. the front passenger side is more stable and I'm not getting the drops i was seeing before. but within a hour when i park the front passenger is back down to the bump stops. i have checked with soapy water the hose that goes to the bag its good. i check the new valve body no leaks. i checked the big nut on top no leaks. any ideas 2006 Range Rover HSE |
Ok so here’s where I’m at. My front passenger wheel drops down to almost the stops within a hour. Even with the door open. With the truck on it with keep the wheel up and I don’t get any hard codes. The strut is new I have done the soapy water test. I replaced the front valve body I traced the air line back to the tank with soapy water. I checked the rear vale body for leaks. Is there another valve body I could be missing? My thought is that the strut is bad but I cannot find the leak. The speed in which it drops says that the leak should be big but I can’t see it. And why can the compressor keep it inflated? 2006 Range Rover HSE |
