![]() | Home > Camping, Caravanning and Holidays > Towing Assistance - target |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
Ive just installed tow Assist using the IID tool and I have no idea what it’s supposed to do? I’ve set up all the caravan dimensions on the screen but nothings apparent since then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I had it. Never found out how to benefit from it. Then the sticker fell off the trailer and blew away. |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I have 3 targets here at home if you need one pm me your address I will get one off to you |
But how does it work? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
It just provides the camera something to focus on and track. Its then able to use an integrated algorithm to forecast where the trailer will end up position based on the current steering angle taken from the sensors in the steering wheel. It then draws the additional lines on the screen the same as parking lines that move based on steering angle.
Thanks. Just need to source a target then! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Do you have an L405?
MisterT Member Since: 08 Mar 2019 Location: Lincolnshire Posts: 29 ![]() ![]() ![]() |
I think the L322 has to have surround cameras for it to work, my 2011 AB has it but I haven’t bothered using it, too much trouble setting up each trailer, I can have the job reversed by the time I’ve worked out what the screen is telling me.
The L405 terrain response knob pops up and then you pull it again and it then becomes a miniature steering wheel to control the electric power steering so you dont need to fight the steering wheel with a snaking trailer, just sit back and steer with the knob! |
