Home > Maintenance & Mods (L322) > Transfer case leak (2009 4.2SC with Magner Steyr DD295 box)
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
The new 4.2SC Rangie has an oil leak on the transfer case, spotted on pre-purchase inspection and some money set aside (£450) to fix, knocked off the asking price. Here's a couple of pictures of the transfer case:
I have no idea why the second photo is upside down, it did that when uploaded to the gallery and the crop & rotate picture tool there doesn't seem to work.
Looking at the leak last week it appears to be leaking from the transfer case face seal, between the two casing halves, as the input and output shaft seals are dry - but I'll have a closer look to confirm. I found RRPhil's DD295 teardown thread very informative:
https://www.fullfatrr.com/forum/topic12404.html?highlight=dd295
and from further reading on this forum, it seems that curing a leaking face seal it somewhat hit and miss, and sometimes leaks from other apertures on the casings can present as a face seal leak, requiring more than one go at curing the leak until the root cause was identified.
The reason for posting this was to ask what the consensus was on replacing the three input/output shaft seals at the same time the case leak is fixed (assuming that is the problem)? Since the transfer box has to be removed anyway, and the case halves split open, I think I may ask my Indy (Keith Gott, Alton, Hants) to do the shaft seals at the same time. But on the other hand, if the shaft seals are currently good, why risk disturbing them and introducing the possibility for a shaft leak? Thoughts welcome.
The shaft seals I'm talking about are items 14, 71 and 73 on the diagram below:
Cheers, fanders Thumbs Up
Post #528836 23rd Sep 2019 10:49am
Before going to all that trouble, I would:
Clean up the casing
Check the oil level (brim to filler hole)
Identify location of the leak
See if you can seal it from the outside
just my tuppence worth .
Post #528845 23rd Sep 2019 12:26pm
fanders
Yep I should do that, will do. Thumbs Up
Post #528848 23rd Sep 2019 12:52pm
fanders
Transfer case cleaned up with a good douche of brake cleaner, should be easy to track where it's leaking from now:
I topped the oil level up with the correct grade of oil, rather worryingly it took 0.6ltr (full is 1.5ltr) which probably means it's been leaking for ages.
Post #529023 25th Sep 2019 9:30am
