Home > Maintenance & Mods (L322) > Slight front end knock |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I’ve just had my track rod ends done and encountered the exact same problem. The inners were so cheap it made sense to do the lot |
24th Sep 2019 8:14pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
I have got exactly the same problem with my track rod ends. You will probably find that the adjusters on the rear suspension are seized up too. |
24th Sep 2019 9:17pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Rear end is the next job unless my fitter says he's freed them and anti seized greased them |
26th Sep 2019 9:17pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I just replaced the rears and they were solid did the fronts a few weeks ago due to wear inner and outer when I took the nearside inner out it was cross threaded - I have had the vehicle since 60k miles now on 185k so guess it came out the factory like that mmmm |
26th Sep 2019 11:14pm |
Well all good now new o/s lower arm full new inner/ outer track rod on both sides 4 wheel tracking done , FF feels kind of stable and positive on the road now all done and came in under £300 inc tracking |
1st Oct 2019 6:52pm |
