![]() | Home > In Car Electronics (L322) > Sat nav radio etc |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
IID is the way to go, I just wonder if it's all overheating.
Toby12 Member Since: 19 Sep 2019 Location: Norwich Posts: 4 ![]() ![]() ![]() |
That thought certainly crossed my mind, thinking about it now I had just turned the heater up, so worth a look, thanks for the reply👍 |
Spud Member Since: 12 Jul 2019 Location: Asif by Magic Posts: 130 ![]() ![]() ![]() |
May be of some use, may not. Had a similar issue with head unit momentarily turning on and off few weeks back. Noticed it happening the same time as other systems were drawing power. Didn't think too much of it as dash as been apart more times than i care to remember recently for one reason or another, but that's another story....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35529 ![]() ![]() |
check the battery... ... - .- -.
Certainly worth a look, it has been stood for a while, although the at it starts you wouldn’t think it’s that. |
the FF has a knack of diverting power to where it needs it if the battery is under par....it will keep the ciggy lighter sockets off and sometimes the nav screen as well..
Evening fellas, a quick up date on the problems with the car, I have changed the battery, pulled apart all connections etc in the rear N/s boot area and sprayed with contact cleaner and re-connected, I haven't had the opportunity to take it on an extended test yet so not certain it's got it but am hopeful.
