Home > In Car Electronics (L322) > M O S T problems Battery related?
Classic888
Hi all. Well after a lack of thought on my part the battery on my vehicle needed to be removed and charged. Having replaced the battery yesterday morning I now have a number of gremlins. I have read a good number of the threads and have a very similar issues raised by others. Volume knob does not work, no CD, AUX or TV/DVD play, plus no Bluetooth. Added to this the steering wheel voice control button does nothing. Last of all the infotainment screen does not go off straight away when the engine is turned off! The battery is about a year old and a quality one, voltage is around 13.5v when running and no water ingress in the rear anywhere. One post mentioned the reset of the MOST system, how is this done? Big Cry
Post #528641 20th Sep 2019 4:37pm
when you re-fitted the battery did you turn the steering wheel fully left and then right.. ... - .- -.
Post #528642 20th Sep 2019 5:04pm
Classic888
Stan. That's a big NO. Could this really affect the vehicles MOST system? Will try later. Thanks.
Post #528643 20th Sep 2019 5:13pm
ahem...
most problems are battery related
Laughing .
Post #528644 20th Sep 2019 5:54pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
A trick that I have found is with a set of jumper cables connected to the terminals of the car before you disconnect the battery
and the other ends connected to the new battery making sure that they don`t fall off, Then disconnect the old battery That then stops the car thinking that the battery has been changed.
Post #528645 20th Sep 2019 6:11pm
Classic888
Stan. Tried the lock to lock yesterday. No change with any of the functions. I am convinced it is a corruption of the files. Looking at having the system flashed.
Post #528801 22nd Sep 2019 9:02pm
lock to lock 'after' a battery disconnection? ... - .- -.
Post #528802 22nd Sep 2019 9:06pm
Classic888
Indeed it was.
Post #528803 22nd Sep 2019 9:08pm
