Home > Maintenance & Mods (L322) > Westfalia towbar install
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I managed to find time this week to swap the Westfalia towbar over from my dead TDV8 to my new 4.2SC Rangie. Here it is installed on my old TDV8:
I removed it (reverse of installation) without much difficulty, but it was a bit rusty on the surface so rubbed the paint down a bit and gave it a few coats of Hammerite Satin Black direct to metal paint:
Installation involves removing the rear bumper, crash bar and most of the boot interior:
The standard Westfalia towing (non towbar) brackets, left and right side, had to come off:
Whilst I was in there I painted the exhaust backbox with VHT Black paint, came out a bit matt for my liking so will probably top coat with normal satin black when I get a chance:
Offering up the heavy towbar assembly was a bit of a faff but a supporting it on a couple of axle stands helped:
Having read about water ingress into the boot due to leakage via the rear crashbar bolt holes, I sealed all mating faces with gutter seal, which remains flexible and doesn't bond too strongly in case the towbar needs to come off again:
Once the four big towbar vertical bolts and the eight crashbar nuts were torqued up, and the exhaust hangars rebolted, it was just a case of swapping the towbar wiring loom over from the old TDV8. My 4.2SC was built with towing preparation (T/TOW HTH-PREP/ROW) which I think means the wiring loom had the connector for the towbar electrical harness, which looks like this:
And installed:
Job done:
Looking forward to plenty of towing now.
Post #528141 15th Sep 2019 9:33pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Very good!
I have the same bar, but I do wonder how the ball stays attached! You just push it up and to my untrained eye, not a lot holding it in place! Still, I am sure it will be OK.
Post #528163 16th Sep 2019 7:49am
fanders
Thanks!
The removable tow hitch/ball is retained in the vertical fixed tube with a locking knob, which you pull out to allow the hitch/ball to fully engage and then twist the locking knob which then allows it to move inwards about 1/4", locking the hitch/ball in place. You can then remove the key from the locking knob. These hitches seems very reliable (see info on this forum about failure of the earlier JLR own-brand version) but you do need to be certain that the removable part of the hitch is properly locked in place, before towing. Hope that helps!
fanders Thumbs Up
Post #528178 16th Sep 2019 9:14am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Nice job, looks smart.
What's the fate of the TDV8? Crying or Very sad
Rich
Post #528186 16th Sep 2019 10:03am
fanders
TDV8 is being broken slowly on my driveway - I've promised my wife it will be gone by Christmas. I'll be keeping a lot of parts in store for long-term use on the 4.2SC (it's often very useful to have a known serviceable spare for use in fault finding), with other bits I don't want being sold along the way. Then - off to the scrappy on a trailer for Christmas. A sad fate for a great car but I had plenty of use out of it.
Salute, fanders Cool
Post #528189 16th Sep 2019 10:43am
RichM63
Might be interested in the side bars from the TDV8, maybe also a 20" alloy.
Have friends in Petersfield who can deliver.
Rich
Post #528370 17th Sep 2019 7:27pm
fanders
Hi, thanks PM sent Thumbs Up
Post #528385 17th Sep 2019 9:40pm
RichM63
PM replied to, (I hope?) Thumbs Up
Post #528412 18th Sep 2019 7:32am
Gsxr1250dave
Just what iv been looking for, a how to step by step guide as I intend to fit a Witter tow bar not so much for towing but to mount a rear tow bar mount to for my spare as iv lpg I leave the spare ar home.
Post #530802 13th Oct 2019 10:11pm
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
GSXR1250dave
I've installed a Witter tow bar to an L322 and written it up for a mag. If you want a step by step guide, just pm me your email address and I'll send you over a PDF. RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #531328 18th Oct 2019 4:02pm
Gsxr1250dave
Thanks that would be handy iv not picked up the tow bar or rear spare wheel mount yet but iv fitted my roof rails and dropped the top box on
Post #531563 20th Oct 2019 7:07pm
NVB
Drop me your email address by pm and I'll get the PDF over to you. RR History
Post #531919 23rd Oct 2019 3:01pm
Danwilderspin
Good job I fitted the same to my 4.4 a couple of years ago but I find it ugly as sin! Why does it need to be so big and stick out - I took the bolt and pin out and made it more detachable!
My new 4.2 has a gdw system far more discreet and seem a lot less to go wrong touch wood Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #532364 27th Oct 2019 11:00pm
