Home > Technical (L322) > Gearbox question (TC) not the usual symptoms I read about
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I have read and read, but failed to find anything that matches my exact question.
As you know I bought a 2004 4.4V8 petrol FF, and I seem to have fallen in love with it a bit-and now my Disco 4 is being repaired by the warranty co, I am in a mess deciding which to keep (or shall I keep both Whistle ).
Gearbox is smooth-really bloody smooth in every way.
But the car has an almost imperceptible vibration at pull off. That is, 1st gear at about 100-1500 rpm and the same in second. Nothing after that in any gear, No cattle grid effect at 50-60, no fluctuation in the revs when TC is locked. Its a joy to drive. Better and smoother than my Disco 4 6 speed box, that has been mega flushed and that had no issues before the flush, purely preventative maintenance. No one else can feel this!
I must point out that the cam covers are leaking and the PCV hoses are like putty and collapsed. These are being done next Wednesday, along with the oil seperater and PCV valve, so all 4 pipes and the 2 parts. I have had an engine light on for misfire on cylinder 2, which was oil in the spark plug well, which I cleaned up and reset the code with the IID. There are no codes at present and all the values for torque converter and solenoids etc look good, as are all the pressures.
Could it be the TC with those symptoms or could even the collapsed PCV hoses do it? Could it be that the spark plugs are not 100% at those revs (they are being changed next week too)? Anything else come to mind?
I will be dropping the gearbox fluid and replacing the filter at the weekend anyway, again as its good practice and knowing its done keeps me happy!
Cheers all.
Post #528342 17th Sep 2019 5:22pm
philip1972
Oh, and while I think about it, I was changing the oils last weekend, and there seems to be a rubber mount of some sort that the rear diff is attached to (in front of it) and that looks well worn. Could that do it?
And if anyone knows what that parts is called let me know, because that could do with being replaced anyway.
Post #528345 17th Sep 2019 5:33pm
philip1972
Looks like that is called a rear cross member insulator
Post #528347 17th Sep 2019 5:43pm
DrRob
Maybe ask Tim at Alltrack in Malvern to take a look ?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528360 17th Sep 2019 6:35pm
philip1972
I have actually moved from Worcestershire, I will update my profile!
Anyone of you gurus any suggestions on the vibration issue?
Post #528417 18th Sep 2019 9:03am
Dolphinboy
If its a knocking noise on roll off, could be the rear transfer box. Needs examination for poss propshaft alignment fault and prob an oil change. Thumbs Up
Post #528427 18th Sep 2019 12:49pm
philip1972
Thanks. No knocking at all! I have changed both diff oils and transfer case.
Post #528428 18th Sep 2019 12:54pm
Dolphinboy
transfer Bearing? or the flanges deteriorating? Dunno otherwise. Sorry.
https://www.fullfatrr.com/forum/topic48232...t=transfer
Post #528431 18th Sep 2019 1:01pm
ur20v
A Trap
You mention plugs and PCV hoses not being in the best condition.... get these replaced before delving too deep elsewhere as you could be running lean and have misfires which might manifest at that rpm range.
Deal with what you know.
Post #528456 18th Sep 2019 4:09pm
philip1972
Post #528474 18th Sep 2019 6:19pm
