Home > Maintenance & Mods (L322) > [SOLVED] Remote Locking/Unlocking not working
Brainszoo
England 2005 Range Rover Vogue Td6 Baltic Blue
well that was worth the read, thank you for the effort put into it, I was able to follow the list and got synced with out to much trouble.
Post #528198 16th Sep 2019 11:26am
Thumbs Up .
Post #528223 16th Sep 2019 12:48pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Step 4 - write changes to BCM permanent memory
Put the key (that was used to start the session) into ignition lock (MUST be same RFID as Step 2
interesting, but what is BCM and RFID RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #592699 29th Apr 2021 3:04pm
Merchy
BCM means Body control module - Typically in a car the BCM controls the power windows, power mirrors, air conditioning, immobilizer system, central locking, etc. The BCM unit is probably under one of your front seats, at least it is on a 2006 RH drive car. Whistle
RFID means Radio Frequency Identification, which is used for car keys to let you start the car, this uses the transponder in your car key. ( Passive RFID system ) Same as credit cards, security tags on store products.
Glad you are now sorted. Thumbs Up
Post #592701 29th Apr 2021 3:32pm
knares
thanks RR 2005 4.4 petrol
Post #592840 1st May 2021 2:55am
