Home > Technical (L322) > Rear parking sensors - how to troubleshoot? |
Wheelnut2000 Member Since: 08 Jul 2018 Location: West London Posts: 14 |
A gap iid tool would tell you which sensor is faulty |
15th Sep 2019 2:08pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
How do you know its the rear playing up sir? The front & rear work in sync with each other! If you have a towbar? plug in the electrics and see if the front works correctly?, that's the only way without diagnostics kit |
15th Sep 2019 2:18pm |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
As a basic check you can put your finger on them and you'll feel a faint pulsing. Might tell you if one or more are not working. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
15th Sep 2019 4:57pm |
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 |
Have a good look at each sensor. A common issue is where the paint starts to blister and close the gap around the sensor. This causes the long beeeeeeep as if your right up against something. |
16th Sep 2019 2:22pm |
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 |
No remedy to this yet, the dealer says the only error code refers to the LED. (Which is what my basic fault coder reader says too).
28th Oct 2019 3:14pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 |
Had this on a Jag I had a few years ago, I was under the impression that a 'long beep' meant one or more sensors were inactive & not the whole system?
28th Oct 2019 4:01pm |
IID says all sensors are OK, the error is something like LED short to battery - whatever that means! The LED in the button is working.
1st Nov 2019 2:45pm |
Oh, and I think it'd be very difficult to hear the ticking with the engine running. And since my gear change is a knob, I don't think there's any way of selecting reverse with only the ignition on.
1st Nov 2019 2:46pm |
