Home > Off Topic - Other Cars > Any ABS experts
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Any ABS experts
Gents
Got a feeling my ABS module may be on its way out on my Audi A4 2003 3.0 petrol, as getting 2 dash lights up after a few minutes driving, ESP and the ABS light. Going to get it scanned this weekend hopefully to confirm. apparently its a common fault on older Audi's
I've been told it will it need re-coding or programming if I buy a used one from eBay, is this true? I have searched and asked on an Audi forum I use but its pretty quiet over there, so thought I'd ask you lot too Thumbs Up
Post #527744 11th Sep 2019 11:29pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
It will need coding but if you have VCDS you can do I yourself fairly quickly and easily. There are many people selling VCDS on eBay with the dongle but make sure you get the full version not the lite one.
You will need to scan your old / existing abs module and copy down the abs coding information from the long coding helper, then swap the new module in and write in the old abs module coding. Sounds obvious but VCDS isn’t intuitive so I’d watch a few YouTube videos first.
I use audi-sport.net as it has a very active U.K. membership. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #527771 12th Sep 2019 8:07am
mrblonde
Thanks Marine Thumbs Up
Had a scan this morning with a friends Snap-On scanner and came up with 2 errors
Brake pedal switch
Rear ABS sensor
So hoping its just those 2 need replacing, fingers crossed!
Post #527884 13th Sep 2019 10:06am
UK Marine
They are two very common problems so good luck in fixing Thumbs Up ______________________________
Simon
Post #527885 13th Sep 2019 10:09am
You will enjoy changing the ABS sensor at the rear (not)
On my Cabriolet the rear seats had to come out, along with the rear side trim, in order to access the connector! Turned a 10 minute job into a 4 hour marathon! (removing the rear head rests was a right sod)
The body/chassis is also double skinned in the route for the cable, so tie on a piece of string in order to pull the new cable through.
Also check the reluctor ring for rust and crud, if you clean that up things may start working again.
The pedal switch may just need some fettling and a squirt with contact cleaner .
Post #527890 13th Sep 2019 11:11am
mrblonde
Cheers guys
Joe90, I have just ordered the rear ABS sensor and was wondering as the cable looks about a metre or longer on the photo, nuts. Was hoping it'd be a quick join near the hub, didnt know it'd be half the car out to get to it Big Cry
The brake pedal switch loooks a piece of cake, so thats first to do when it arrives
Post #527928 13th Sep 2019 4:42pm
I was sorely tempted to cut the new one and splice on to the old one.....but Audi must have had a reason (not that I ever had problem with the connectors on the FFRR being right in the firing line) Smile .
Post #527960 13th Sep 2019 9:35pm
mrblonde
Joe90, that was my way of thinking, either a days work and a bad back, or 20 minutes work.....
crude and unprofessional i know, but it wouldnt be the first time I was called those 2 words Big Cry
Post #527990 14th Sep 2019 1:55pm
