Home > Technical (L322) > Rear Ride Height Wiring Fault
Mikem
United Kingdom 2010 Range Rover Vogue TDV8 Atacama Sand
Had mine checked yesterday and its showing a fault on the left hand side rear the garage have recommended fitting a wiring repair kit as its a common problem how much of a job is this to carry out or is it a garage job
Post #526492 29th Aug 2019 8:29pm
Mikem
Any ideas on this apparently its a common problem with wires getting corrosion
Post #527489 9th Sep 2019 8:59pm
GGDR
I had chaffing near the drivers side height sensor, fixed it myself pretty easily.
. Cheers, Greg
Post #527495 9th Sep 2019 10:01pm
