Home > Technical (L322) > HVAC always warm
JonnyO
United Kingdom 2004 Range Rover Vogue 4.4 V8 Stornoway Grey
HVAC always warm
Think I may have found a reason why my newly purchased L322 2004 Vogue 4.4 petrol was so cheap 🙂
Came to put the aircon on driving home and all that would come out was warm air. Not just ambient warm, heated warm. No matter where I set the temperature controls.
Anyone have any ideas where I should start investigations?
Post #527389 8th Sep 2019 7:21pm
Mikey
An AC gas leak Thumbs Up
Post #527390 8th Sep 2019 7:28pm
JonnyO
If that was the case, wouldn’t I expect the air to be just at ambient temperature, not heated up?
Post #527404 8th Sep 2019 9:03pm
cass
Has it got LPG fitted?
I used to have a BMW 540 and the LPG vapouriser had been plumbed incorrectly causing constant hot air
Post #527420 9th Sep 2019 12:33am
JonnyO
Nope. No LPG. 100% standard
Post #527422 9th Sep 2019 7:05am
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
As Mikey says I'd check the air con is gassed. If thats OK and holding the pressure I would suspect the compressor is stuffed. If you can check the live values and fault codes that would confirm. Also try selecting the max air con button if that doesn't make any difference at all then that's your most likely cause. When my compressor died the fatty was blowing very warm all the time no matter what setting just like yours and got so bad we were driving with the windows open just to get some cool air in. Trip to the garage me thinks
Post #527491 9th Sep 2019 9:26pm
Gsxr1250dave
Most likely cause is this I had it on mine drivers side was all ways hot
https://rover.ebay.com/rover/0/0/0?mpre=ht...2356783074
Post #527509 10th Sep 2019 12:02am
JonnyO
I was wondering if it might be that valve.
Did you change it yourself, or did a garage do it? Any idea if its an easy DIY job? I assume the calling system has to be drained down to do it?
Post #527518 10th Sep 2019 9:50am
JonnyO
Oddly the HVAC started working again bit after this. Now the car is sold so I never did get to the bottom of this.
Post #564852 17th Aug 2020 9:44pm
