Home > Wheels & Tyres > Pirelli Scorpion Zero 255/55/R19 M and S Tyres
I understand that the above tyres are asymmetrical and can be run either way round as long as they are fitted with the "outside" of the tyre fitted to the outside of the wheel.
Try as I may I can't see any indication on the tyres as to which is the inside and which is the outside. Confused
Having looked at my present same model tyres I can't see any indication on them either.
Before I fit my new tyres does anyone happen to know how these tyres are marked "outside" or "inside".
At present I can't see what difference it makes at all.
Thanks.
Post #527256 6th Sep 2019 5:24pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Well the rubber on the 'inside' of the tyre tends to be a dullish uniform lightish grey with undulations, and may leave a floury powder on the hands.
Whilst the rubber on the 'outside' of the tyre tends to be very dark grey with a deep patterned segmented appearance, and various writings in relief.
HTH, Wink
Rich
Post #527260 6th Sep 2019 6:09pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
As a general rule the DOT code ( date of manufacture ) would be fitted to the outside if there are no other markings. It is only with directional tyres where the DOT code would be on the outside on one side of the vehicle and the inside on the other. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #527286 7th Sep 2019 7:27am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Hmmmmm....... mine have “Outside” stamped on them, as they were on a set of wheels I bought and I wanted to check they had been fitted correctly.
I’ll check for you.
Jim
Post #527288 7th Sep 2019 7:45am
Weegie
Nicedayforit, Are you sure they are asymmetrical? My understanding, which may well be wrong Big Cry , is that Pirelli include the word "Asimmetrico" in the description of such tyres. John
GAP iiD BT
Post #527290 7th Sep 2019 7:53am
pawsinmud
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Do you mean the Scorpion Zero that we have all traditionally had, which are not asymmetrical or directional:
https://www.blackcircles.com/catalogue/pir...20Products
or do you mean the new Scorpion Zero All Season, which is a brand new tyre from Pirelli and is asymmetrical:
https://www.pirelli.com/tyres/en-gb/car/fi...llery-cake
You will see from the pictures that the tread pattern is different and the latter has OUTSIDE clearly marked on the sidewall.
The old one is no longer on Pirelli's website and I imagine only old stock is still available. All new Land Rover seem to use Scorpion Verde All Season instead. 2011 TDV8 Vogue SE
Post #527293 7th Sep 2019 8:19am
jim4244
Ahhhh..... Sorry. I thought you were talking about Pirelli Verde All Season M+S.
Jim
Post #527294 7th Sep 2019 8:35am
Thanks for all the observations gents.
The tyres are Pirelli Scorpion Zero 255/55/R19 M & S 111v xl.
They are dated 0919, so not old stock.
The dot marking is printed on both sides of the tyre, indeed all the printing on each side of the tyres is identical.
There is definitely no outside/inside markings on the tyres.
There are no tyre rotation markings on the tyres.
The tyres are definitely asymmetrical, the block pattern is handed.
I have decided I am going to fit them with the grooves in the outer block pattern facing backward, to do this two tyres have to be fitted 180deg out so that the pattern is correct for both sides of the car.
Hopefully this may help someone else fitting these tyres in the future. Thumbs Up
Post #527296 7th Sep 2019 9:11am
pawsinmud
I agree that it is confusing. There are many tyres that have Scorpion in their name. I believe the most relevant to us are these three:
Pirelli Scorpion Zero. No longer available, but was OE fitment on my D3 (2009) and D4 (2016). Most online retailers still list them though, but prices dropping, probably as a consequence of being discontinued.
Pirelli Scorpion Zero All Season. A new tyre, although not sure of the release date. Don't seem to be type-approved by JLR at the moment and are also rare and very expensive on online tyre websites.
Pirelli Scorpion Verde All Season. The current OE fitment for most Land/Range Rovers.
If you look at Pirelli's website, you will also find Scorpion Verde (in addition to the All Season version of same), Scorpion All Terrain Plus, Scorpion ATR, Scorpion Winter and Scorpion Ice & Snow!! 2011 TDV8 Vogue SE
Post #527297 7th Sep 2019 9:13am
Confusing it certainly is.
At present my car is fitted with the same tyres, which I bought off LR as a set of wheel/tyre take offs back in 2012 so it is fair to say I have had my monies worth. Very Happy
Never had any problems with the tyres hence I bought like for like.
When I fitted the original wheels I was obviously lucky as to what wheel went where as I don't remember even thinking about what went where but they were correct.
Presumably if I have a puncture and used the spare it could be handed wrongly depending on the side of the car.
I had no problem finding these tyres, albeit they came from Germany in two and a half days, they are obviously still readily available, they were only made last week.
Just be glad to get them fitted now for another 8 years. Rolling with laughter
Post #527301 7th Sep 2019 9:42am
pawsinmud
The date code is week and year, so 0919 means week 9 which was March this year.
I only went by them no longer being on Pirelli's website as an indication that they are not available, but I do not know when (or even if) they have stopped production. It would seem the new tyre is its replacement, but few online retailers list it.
I found them fine on both my Discos and they last a long time - I got more than 40,000 miles from the first set on my D3 and only changed to Grabber AT as I wanted more aggressive tyres for off-road use. 2011 TDV8 Vogue SE
Post #527303 7th Sep 2019 9:50am
Post #527304 7th Sep 2019 9:52am
