Home > Maintenance & Mods (L405) > Adjust position of deployable steps? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
4th Sep 2019 11:23pm |
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 |
I suppose I should have clarified. The steps came with the car and I have disabled them since I don’t use them. My hope was that there are some bolts somewhere that allow for fine tuning of the position of the steps so I can get them tucked away nice and tight, so I don’t have to see the huge air gap between the sill and the step. . 2021 P525 | Eiger Gray |
10th Sep 2019 12:18pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Would removing them not be a better option ? 2015 4.4 AB
10th Sep 2019 1:22pm |
Thought about that. But the side steps require a different kickplate panel below the door line, so I'd have to purchase a set of the standard panels to replace. 2021 P525 | Eiger Gray |
10th Sep 2019 4:53pm |
Not sure what the kick plate panel is but if its required then the cost might be the deciding factor for you. 2015 4.4 AB
10th Sep 2019 5:01pm |
