Home > Maintenance & Mods (L322) > Driveshaft popped out of front diff?
Danwilderspin
Had a very weird one today in my 4.2 has anyone had this or any ideas?
I started it drove 3 miles and it sounded like the viscous van was on full speed all the way I could here in the cabin.
Got to a roundabout and stopped put my foot down and there was no drive? Put it into park then drove again and it just revved tried again got drive.
I then got where I needed and tried to review same again then put in drive and got a weird noise. I then fixed the fuel pressure thinking the worst but it’s fine again pulling like a train in every gear and crawling nicely in reverse and drive? Also lowrange is all good?
Any ideas? Maybe one for rrphil? Is this the common start of something or could my wheel speed and fuel pressure have caused it?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526394 28th Aug 2019 9:40pm
Danwilderspin
Just an update to this It’s happened again!
This time it was with my lpg fitter he got it on the ramp immediately as it did it right at his place and the left hand front driveshaft had popped out! He got it back in after much struggling but wondered if this is something that happens or is likely to happen again or if I need to be changing something as I can’t have this keep happening?
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526826 2nd Sep 2019 1:52pm
IMHO, there has to be some major problem with the front suspension joints to allow the hub to move away from the diff sufficiently to disengage the splines. No front suspension system is designed to allow that under normal conditions. The shafts are basically floating in a space smaller than their length.
Knackered CV joint ?
Knackered wheel bearing?
Knackered suspension ? .
Post #526873 2nd Sep 2019 8:13pm
Danwilderspin
The cv joint had recently been replaced - any chance they could not have quite put it back together right and now Its back in it could be ok? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526904 2nd Sep 2019 11:22pm
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
There is every chance that they didn't get it fully infor the ring to locate but this also happened to me on a 4.2. See a post of mine about it. In my case the locking ring was broken in two and no work had been done on it previously. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #526918 3rd Sep 2019 7:37am
Danwilderspin
Thanks - I have messaged the garage it’s at to check that they say it all looks in ok but I’ll get them to confirm the clip Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526921 3rd Sep 2019 8:06am
j_rov
They might have used the old clip. I did on mine and it pulled out after a week or so. New clip and never happened again.
There's an audible engagement sound when it goes in properly. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #526925 3rd Sep 2019 8:48am
Danwilderspin
Ok bard on this I have booked it into the Indy next week to strip back and replace the clip and anything else that looks not quite right... will keep you posted Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #526956 3rd Sep 2019 2:17pm
