Home > Off Topic - Other Cars > power steering fluid questions
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Ive asked on an Audi forum (we have a 2003 A4 3.0 v6 petrol), but got very few responses and still couldnt find out after a search either........
So, thought I'd ask you boys, seeing as you're so helpful with the RR Bow down Thumbs Up
where can i find out how much power steering fluid my car takes, if i want to change it? (any fluid capacity specification sites you use?)
And, how would i go about changing it? suck it out from the reservior, or drain it off from somewhere else?
Post #526661 31st Aug 2019 4:14pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Does it have a dipstick on the filler cap. I remember my BMW's had that.
As for draining I saw Edd China change the fluid on a car, 320 Touring if I'm not mistaken, and he undid a union at a low point in the system and let it drain out, did the union up and filled the system. Then turned power steering from right to left (sound familiar) until all the air had burped out of the system. Power steering back to normal. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #526668 31st Aug 2019 5:21pm
I have been all through ELSAWIN for the V6 no mention of capacity.
Suggest you get yourself a couple of litres and do what I did with a syringe:
Suck old fluid out of the reservoir until empty, refill to level with new fluid. Drive car for a day/while - using the steering
Repeat until fluid in reservoir looks like it is the new stuff.
My FFRR took @ 1.5 litres .
Post #526674 31st Aug 2019 6:38pm
mrblonde
Cheers guys
I topped it up (the reservoir was empty and steering was whining) and it only took about 200ml, done a load of left/right turns to get it through the system, then out for a 10 mile drive, checked again. all OK. Ive got a couple of 100ml syringes so will draw out as much as i can and replace it a couple of times (got 2 litres of the stuff, so may as well do a couple of suck out/refills
Incidentally, would the fluid level drop of a very long time, as in years? Embarassed You know, for example if you had a Mrs who never checked it??
Post #526736 1st Sep 2019 12:14pm
Probably - just a very small leak somewhere....
Mine never lost any fluid in 8 years - checked weekly though... .
Post #526741 1st Sep 2019 1:27pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
If the seals are leaking slightly , Lucas Power Steering Stop Leak is effective
Worth checking the hoses first though as these often fail 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #526769 1st Sep 2019 7:32pm
mrblonde
Cheers all
Checked all hoses for leaks, sadly nothing Sad
I'm guessing the whining means a knackered PS pump? Any ideas what kind of job it is on a 3.0 v6 petrol Audi A4?
Post #531777 22nd Oct 2019 1:21pm
From the manual look like a bit of a nightmare
Remove bumper
V belt off (check rotation) & removing everything that entails...
Disconnect A/C compressor (but do not release pipes)
Remove PS pipes and clamp
Remove PS pump
Sounds easy enough, but there is not much space in there
Can't remember if it is front right or left .
Post #531785 22nd Oct 2019 2:38pm
mrblonde
Hi all
Late request for help again Embarassed Embarassed
Finally got round to replacing the PS pump and belt 2 weeks ago, have only driven it about 20 miles and its making a whining again. Checked the PS fluid level, thinking it may of taken more into the system (we manually primed the pump before fitting it, then primed in on the car before use) and it was a lime green colour, not the clear, dark green fluid colour we put in when we changed the pump?
Any ideas please guys?
Post #547434 17th Mar 2020 11:58am
