Home > Technical (L322) > 4.4 TDV8 Auxiliary Belt
dhallworth
Gents,
Our 4.4 TDV8 developed a chirp from the auxiliary belt when it was cold at around 16k miles. 18 months ago the tensioner was replaced and the chirping stopped for a few weeks and returned. It's now covered 19k miles and we've been told to replace the 3 idlers and both belts by the local independent. They've quoted 5hrs labour to replace the 3 idlers and 2 belts.
Does anyone have a guide on how to get to the components? I've had a look and it looks to be quite a strip down to get to it but I'd be interested in seeing what the manual says as I'm half tempted to do it myself.
Post #526549 30th Aug 2019 1:07pm
Baltic Blue
The manual is now available if you look in the Wiki.
Post #526550 30th Aug 2019 1:15pm
dhallworth
Thanks Mike,
I found it just after I'd posted. Am downloading it from Google Drive just now.
Post #526551 30th Aug 2019 1:21pm
my tdv8 chirped for the 3 winters i had it ...the noise didnt last long and i just ignored it.... ... - .- -.
Post #526552 30th Aug 2019 1:21pm
dhallworth
This one does it every time it's cold and it lasts for 5 minutes or so until it's warmed up. It's not bad, it's just irritating when you get out of it whilst it's still cold and running. Laughing 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #526554 30th Aug 2019 1:41pm
Baltic Blue
5 hours labour sounds a reasonable quote to me, plus they will have the special tools required.
Post #526555 30th Aug 2019 1:58pm
dhallworth
It isn't a bad quote at all. Some jobs I quite enjoy doing myself and I'm just wondering if this is one of them Smile
Post #526556 30th Aug 2019 2:57pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Or a can of Carplan Beltup which is what i use on the L200 which always has a chirpy belt. Have to reapply it every now and again. It lubricates the belt as they can dry out a bit. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #526578 30th Aug 2019 6:06pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Just had mine done by an Indy in Littlehampton, it was noisy for about 2-3 min. Apparently there is a modified alternator bracket which resolves the core issue think he said there is tsb referencing it. Cost roughly £875 to rep idlers, bracket tensioner & belts - gen parts
2011 tdv8 110k
Post #526583 30th Aug 2019 6:43pm
DrRob
Which indy in littlehampton? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526589 30th Aug 2019 7:12pm
QuebecTango
Charnocks automotive,Riverside ind est, Littlehampton
Post #526592 30th Aug 2019 7:56pm
