![]() | Home > Maintenance & Mods (L322) > Illuminated sill plates Repair |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I'm not sure EL is really bright enough for this application. I bought a new set of sill plates and I can still barely tell they're illuminated. The LED puddle lights probably don't help.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
The 5050 led strips I used are really bright - helped with being blue they really stand out. Very good value less than £10 for 4 x 30 cm lengths, only needed 2 to do the job but thought would have some spares! Don’t need transformers just wired into existing loom. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Actually £3.99 for 4.
Thanks for that. Ordered some now. They look very nice - might find a use for some in our camper too! 2010 4.4 TDV8 Vogue SE |
If I remember they are polarity sensitive so check they work before doing the final connection in case + / - need swooped over. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Corsica Member Since: 03 Jan 2019 Location: Corse Posts: 50 ![]() ![]() ![]() |
A question? I would like to mount the ignition plates or I can plug in to power them
If you have the illuminated sill covers Just use the existing wires that are on when you open the doors and the interior lights come on. Would be too distracting if wired through ignition 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Can you tell me how it disassembles... thanking you |
See first post in this thread 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Have a look at my metal tidy up too:
D Hallworth this was my original post rebtread plates hope this helps 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3151 ![]() ![]() ![]() |
Thanks Bob.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 123 ![]() ![]() ![]() |
Thanks to this thread, I sorted my sills yesterday and they’re now a bright white. It’s little things like this thread which make the forum what is it! |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 199 ![]() ![]() ![]() |
Timely reminder here that having bought these led strips they still need fitting!
