![]() | Home > Technical (L322) > OBD II Reader |
I take it you ran the installation CD for program? |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
There wasn't one |
Without installing the software how can you expect it to work? There has to be a related program to read the data? |
OK, which version of Windows 7, specifically is it 32 or 64 bit ????
Thanks Dom.
I'm with Gaz on this one, regardless of your system, if you don't have the correct drivers (and Windows 7 doesn't appear to have them on board, which means XP is everso less likely to have have them) you won't get a proper connection. Go back to your supplier, or check out their website for the drivers for your device. .
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
If you think it's a compatibility issue, you just copy any related software into a folder and right click on the 'exe' program and select 'test compatibility' and Windows 7 will check program /drivers and choose a compatability mode (bit like on XP where you could choose to run a program as win 95 /98 ME etc). May help you and saves running XP under VM Ware Steve
I've tried the interface now on 3 different machines, Windows7, XP and Vista and every machine see's the hardware but when loading Digimoto or Scantool i get the "interface not found" message.
OK, you might be right in assuming it's duff.
