Home > Off Topic > Replacing my knackered pressure washer |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 |
loads on machine mart from about £800 upwards... ... - .- -.
2nd Mar 2011 1:30pm |
What you have to remember with hot pressure washers is the amount of power they take to operate. A household socket can handle 13 amps and you can go up to 16 without too much worry, but when you start going higher than that you can run into problems and this is the reason most heated PWs are 3 phase.
2nd Mar 2011 1:47pm |
Paulo Member Since: 28 Sep 2010 Location: Glasgow Posts: 199 |
I agree with Alan, I too have a Nilfisk C120 which replaced a Karcher, great bit of kit for the money.... |
2nd Mar 2011 2:31pm |
Alan |
2nd Mar 2011 2:58pm |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
i use a Karcher K7.85M
2nd Mar 2011 2:59pm |
mrjamescollins Member Since: 17 Jan 2011 Location: Braintree Posts: 42 |
another vote for the Kranzle here. |
2nd Mar 2011 3:33pm |
Ooopsss.... My memory for names is legendary.... Sorry.... |
2nd Mar 2011 3:47pm |
No problem Billy |
2nd Mar 2011 3:54pm |
Check out the Nixon range. Big and very farmer-ish. Based on Kranzle fittings and easily replaceable pumps etc. Proper pumps which have the ability to change oil etc. Diesel or kerosene fired boiler for hot wash and variable pressure at the nozzle (adjusted on the main pump valve)
2nd Mar 2011 6:47pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
I use the hi end domestic Nilfisk Alto its about £320 but being a domestic come with 3 year warranty, has foam lance and own pick up unit and you can run up 80" water through it ( i never bother ) snow foam and cold water is fine. Far to many gone... |
2nd Mar 2011 8:36pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2031 |
CPC do a good line of Nilfisk:
2nd Mar 2011 9:12pm |
A neighbour has had one of these for a while, which he highly recommends....
3rd Mar 2011 3:03pm |
Sidney Member Since: 20 Jan 2010 Location: Herefordshire/Welsh border Posts: 47 |
We have got through loads of K'archers, will never buy another. Years ago they were well built industrial strength tools, alas no more.
22nd Mar 2011 12:26am |
