Home > Technical (L322) > Jump start fail |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
Are you sure the other ends of the jump leads weren't touching each other? Current:
21st Aug 2019 4:00pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Is the insulation on your jump lead ok? No nicks or worn patches where the conductor could have earthed itself. |
21st Aug 2019 5:00pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
You are certain that the battery connector is properly seated? That you didn't loose connection to the battery for a second while connecting the leads? This happened to me. Worn posts on the battery, and the clamp doesn't allow for much deviation before it bottoms. 2007 L322 3.6 TDV8 Stornoway |
21st Aug 2019 6:07pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
id say you've hooked them up wrong and blown one of the big fuses somewhere |
21st Aug 2019 8:41pm |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
'As soon as it touched the terminal, huge sparks and my car died'
21st Aug 2019 8:58pm |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
This is the thing, I had the positive clamp in one hand and the negative in the other. Other guy was holding the positive and negative clamps at the other end of the leads. Only clamp that made contact with either car was the positive at my end. 2004 Vogue TD6 - Remapped
21st Aug 2019 10:41pm |
WB, by car died, engine immediately cut out 2004 Vogue TD6 - Remapped
21st Aug 2019 10:42pm |
Bembo449, yeah I expected at the least a major fuse to have blown. But nothing blown, started right back up again and everything works normally. 2004 Vogue TD6 - Remapped
21st Aug 2019 10:43pm |
When jump starting the supplying car engine should remain off until both cables are securely attached. Then the supplying car should be started followed by the receiving car.
21st Aug 2019 10:46pm |
WB, valid points. Though in fairness done many a jump start in my time, admittedly not with the RR, and always had the supplying car running while connected. Always connect in order of supply car +, flat car +, supply car -, flat car -.
21st Aug 2019 10:57pm |
As mentioned, check your terminals. Connecting a jump lead to one post with non other connected, cannot cause anything.
22nd Aug 2019 4:46am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
I was always told not to have the engine running when you're trying to jump start another car as you risk killing your alternator as it's not rated to supply the current being drawn.
22nd Aug 2019 6:44am |
