Home > Maintenance & Mods (L322) > Brake bleed procedure TDV8 4.4 2011
j9ffy
France 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Evening all,
For downstream of HCU, workshop manual states, as step 4: "Conduct the bleed procedure with the engine running."
And for step 5: "Connect the diagnostic tool to the vehicle, select diagnostic and proceed as directed for bleeding the brake system."
It (the workshop manual) then proceeds to outline a fairly standard bleed procedure using 28 "centre 1/3" pedal strokes for the rears and 10 similar strokes for the front etc. Order for RHD is RL, RR, FL, FR.
My questions: How important is it to have the diagnostic tool connected? Can this be done without? If required, does the IID tool have this functionality?
Any guidance very much appreciated!
Cheers, J.
Post #525796 21st Aug 2019 11:39pm
nino_nino
this is the way I did mine, no need for diagnostic tool if you don't have air in ABS,
https://www.fullfatrr.com/forum/topic44822.html 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525814 22nd Aug 2019 8:51am
j9ffy
Very many thanks for the information - and for your excellent method. I will be copying your auto-feeder!
Cheers,
J.
Post #525962 23rd Aug 2019 8:10pm
nino_nino
Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525993 24th Aug 2019 9:35am
