![]() | Home > In Car Electronics (L322) > Is this why my stereo doesnt work ? |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
See picture |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Your photos are in your gallery............
Take the lot out -- all units, get lots of contact cleaner and a soft tooth brush, clean everywhere, take the boards out of the boxes, leave to dry in an airing cupboard after using the contact cleaner, reassemble and plug back in, you may just be lucky.
Ok pal , ive thoroughly cleaned it , it was the last unit as id done the others
You can upgrade the CD nav unit to a BMW DVD unit know as a mark 4 -- up to date discs are available for that -- simple swap just wait for everything to sleep disconnect the CD unit, connect the DVD unit Current: 2011 FFRR Vogue SE 4.4 TDV8
Oh right , wheres the best place to find one of them , fleebay ?? |
Just an example -- nothing to do with the seller: -
Cool , least i know what i need , is there any significance in the nav player power light flashing pal ?? You mentioned thing need to go to sleep etc |
I think when it's flashing it just means there's something wrong somewhere -- open the boot leave the car for 10 to 15 mins then unplug units, if you don't leave all the units to go to sleep they can screw up when disconnecting Current: 2011 FFRR Vogue SE 4.4 TDV8
BMG has the whole kit and caboodle for sale:
ok , before I found the problem the power light was steady , I will do as you say tomorrow and see what occurs ? cheers |
quick question guys , ive been offered a MK4 DVD player that doesn't read the disc anymore , im not worried about the NAV part but will it still be good enough to get the stereo working again ??? |
I think you'd have to ask yourself why it doesn't read discs -- if part of it is failing then all of it might! Current: 2011 FFRR Vogue SE 4.4 TDV8
yes that's a valid point pal |
