Home > Maintenance & Mods (L322) > Front air leak?
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Front air leak?
Hi, after having the car jacked up at front on one side to replace a track control arm, I came to it this morning to find it settled down on its front wheels, rear of car is fine.
I fired it up and the car raised normally but I could hear hissing from the wheel arch I'd worked on earlier. Have I dislodged something, a pipe? I'd carefully removed the height sensor to the track arm on that wheel and replaced it without issue. Has anyone got any advice please? Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #525347 19th Aug 2019 9:29am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
It's typical to find an air bag leak after it's been raised beyond it's normal height when jacking or if put in off road height when hardly ever used at that height. Basically the folds in the air bag become uncovered when lifted and the leak becomes apparent as it's the folds that often crack (where they flex the most).
Put it in off road height, if it will go that high, and start investigating with soapy water. Could be a pipe but most likely it's a bag gone.
Post #525395 19th Aug 2019 1:42pm
Rapiscan
I can feel and hear air escaping at the rear of the bag at12o clock position from my 6o clock position as it were if that makes sense? I can actually temp block off the leak with my finger tip, just wonder despite the pressure which I assume is similar to tyre pressure, could tyre weld be squirted into the bag as a temp measure or any other temp measures?? Thanks. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525400 19th Aug 2019 1:53pm
Wouldn't recommend it Shocked You probably won't get very far....
Reservoir pressure is @ 180psi iirc, so not quite the same as tyre pressures...
New struts & bags time, both sides - the other one WILL go pop if you don't replace it first Wink .
Post #525417 19th Aug 2019 3:53pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Be very careful if you try this, I tried it with alarming results. I tried various ways all without success so then I thought a hypodermic syringe. I should have thought it through further but no, I had to have the suspension high to see the area so syringe loaded, suspension high and Dr Kildare at the ready. I inserted the need and syringe plunger nearly broke my thumb as it launched itself with incredible force like a bullet from a gun. Jeez it was powerful, it just missed me and hit the wall about 2 metres away, the plastic plunger actually chipping a brick in the wall.
Get a new airbag and fitting is easy. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #525433 19th Aug 2019 5:19pm
Rapiscan
Shocked Ok def NOT attempting that then.
IF I remove fuse 57 for air suspension, thus making sure the compressor doesn't continually run and burn out, can I then carefully drive the car about 15miles to my mechanic to fit a new strut dya think? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525511 20th Aug 2019 10:15am
Rapiscan
I'm so tempted to have a go myself, worried about undoing those two big nuts on the leg as its almost 12yr old, will I need a 6ft breaker bar? Also is swapping the airline onto the new strut straightforward, with no difference on the new strut compared to old? Thanks. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525513 20th Aug 2019 10:20am
TJH1985
I just used a impact gun on ours, they didn’t put up a fight. Air lines swop straight over, new ones come with new fittings but I always felt it was risky to fit them so reused the old ones. You’ll need a decent size torque wrench to bolt them back up and I used new bolts as they are often damaged when removed.
Doesn’t take long at all to do Thumbs Up
I have done both the strut, and just the air bag and it’s about another half hour to do just the bag.
On both cars it was the drivers side that failed, and both times just a small pin hole as if a sharp stone had got between the bags and worked its way through.
Post #525678 21st Aug 2019 12:02pm
Rapiscan
Thanks for your replies, dya know I think I'll brave it and have a go myself, garage's here want £150-200 labour to fit one. Basically it's undo the drop link, 2 leg strut bolts and 3 top inner wing bolts, then the air connection.. Its that I'm concerned about, why swop it over, wouldn't the new one on the new strut be preferable? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525693 21st Aug 2019 1:23pm
TJH1985
The air fitting is just a olive type setup, I can’t remember the torque setting but it’s not allot (screws into plastic) and as such in my case the olive was hardly touched.. however it was a rather snug fit on the pipe and I just didn’t fancy trying to pull it off the pipe to fit the new one.. I was probably over worried, I have the new ones should they ever be used.
I used leak detection spray on all the joints for a hour after, but a quick check with soapy water would be just as good.
Yours doesn’t happen to be drivers side as well does it?
Post #525696 21st Aug 2019 1:57pm
Rapiscan
Yep it is! Wink I know they are supposed to be done both sides but I'll take a punt, if that one goes it goes, IF I do the offside one at least I'll know the drill! I'm assuming fitting a new control arm on that side a few days ago and jacking up the car has "disturbed" the bag, the fold on it looks crusty but I think it's the original, so 135000its done OK I guess.. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525699 21st Aug 2019 2:22pm
Rapiscan
After fitting you just start the car and let the compressor fill the bag for its first time I assume? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525700 21st Aug 2019 2:23pm
AJGalaxy2012
Yes thats all I did and the car magically lifted up. Dead easy job for sure, not as bad as you think. BMW i3 Electric Car
Post #525705 21st Aug 2019 3:08pm
and don't forget to disable the EAS and release the pressure from the system Exclamation Exclamation .
Post #525706 21st Aug 2019 3:09pm
Rapiscan
With the bag already being deflated due to its leak is that good enough or do I need to empty ALL air from the entire system? If the latter how/where is it released? Thanks. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #525737 21st Aug 2019 4:39pm
