Home > Technical (L322) > Reduced Performance (Limp Mode) No Fault Code
headless21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi everyone, I have a L322 2011 4.4 TDV8 and it randomly keeps going into Reduced Performance (Limp Mode) but does not show any faults (I am using Gap iid tool). It can do it when accelerating slowly or hard, mostly does it when going up long gradient and lightly accelerating. If i press clear all faults on Gap tool it gets rid of the Reduced Performance message and then the car runs perfectly. I did a trip of about 100 miles and it went into Limp Mode 12 times. Can anyone give me any suggestions where to start diagnosis. I have checked all hoses for splits. My car seems to have 2 air sensors one in each air box but I can only see 1 Mass air flow on Gap tool, could these trigger limp mode and not show a fault code.
Any help and suggestions how to get to the bottom of this would be great.
Regards Martin Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
2003 Range Rover Vogue SE
1997 Range Rover DSE
1990 Range Rover Vogue SE
1985 Range Rover 2 Door
1979 Land Rover Series 3
Post #525443 19th Aug 2019 6:36pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I was chatting with GAP recently and they aaid a MAF error would throw up a code. Sorry i can't be more help. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #525446 19th Aug 2019 6:48pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
If teh MAF wiring goes open or short it would then show an error, if the reading were incorrect it wouldnt. I had similar problems when I first got the GAP tool, light on but no errors, there is a setting somewhere to show all errors not just ones that have happened 'x' times. Im away at the minute so cant check, have a look around in the GAP software the next time you have the fault. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #525458 19th Aug 2019 7:30pm
GGDR
Symptoms match split hoses.
Recommend double / triple check your hoses. Cracks can appear underneath or under the hose clamps.
Number of times I've read hoses are fine, then eventually hose splits found.
. Cheers, Greg
Post #525463 19th Aug 2019 8:11pm
headless21
Thanks guys for the quick responses, you have given me a few things to check, I really appreciate your help. 👍 Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #525466 19th Aug 2019 8:19pm
Baltic Blue
Next favourite on the list after split hoses would. be a split in the plastic plenum chamber., usually at one of the seams.
Get a clean white tissue and slowly wipe round all the joints.
Air leaks are usually spotted by finding traces of black sooty deposits near the split.
Failing that get a smoke test done.
Mike.
https://www.fullfatrr.com/forum/topic44115.html
Worth a read Rolling with laughter G reg 2.5VM Vogue Portofino red 1991- 1999
Post #525491 20th Aug 2019 6:54am
GraemeS
The original secondary turbo inlet isolation valve on 4.4's built before late 2011 is prone to sticking. It is high on the list of suspect causes after the 4 short air intake to manifold hoses. However these failures trigger fault codes so is your IIDTool correctly configured to read all fault codes?
Post #525508 20th Aug 2019 9:41am
Baltic Blue
Mine had a stuck valve replaced because of the restricted performance alarm, but it did raise a fault code to help locate the problem. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #525510 20th Aug 2019 10:05am
rjff
Martin
I go with the above. Mine did the same thing and that was the four short hoses one leaking from a split so replaced all four. Clean the MAF while you're in there. Just use electrical contact cleaner and as you have the plenum off clean the sensor in the throttle body.
Be careful of the small pipe leading off the rad hose connectors, easy to break and that's £80 sir.
Set the gap to read all fault status bits before you start to ensure you have as much info as possible. Cheers
Richard
Gap IIDBT
Post #525519 20th Aug 2019 10:51am
