Home > Maintenance & Mods (L322) > EGR delete - TD6
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
EGR delete - TD6
Hi all
I’m struggling to fit the EGR delete to my TD6.
The metal pipe that comes up on the left hand side of the EGR casing and joins it won’t allow me to line up the bolt holes on the delete unit.
Can I bend the pipe or will it just snap? Should I fit the delete when the engine is hot or cold?
Thanks
Jim
Post #525208 18th Aug 2019 9:19am
jim4244
Here’s a photo of what I am trying to explain.
Post #525210 18th Aug 2019 9:22am
That's odd, it should have lined up with the original EGR module ?
Suggest loosen the lower bolts for the EGR pipe to give you a bit of wiggle room, get everything in place - fix the EGR Delete to the crankcase, then tightem up the jubilee clip, then the lower bolts for the EGR pipe. Should all pull together ? .
Post #525223 18th Aug 2019 10:13am
this bit [marked in yellow] looks a bit to long..
Post #525225 18th Aug 2019 10:19am
jim4244
Hmmmm.... This is the second one I have had from the supplier who state that they have never had anyone experience in this problem. This makes me wonder if my pipe has previously been bent out of shape? Is there not a portion of the pipe with corrugations to allow flexibility?
My only other option is to remove a few mm from the blank arm and have it re spot welded.
Decisions, decisions..........
Jim
Post #525235 18th Aug 2019 11:23am
Send it back ?
iirc I got this one
https://www.ebay.co.uk/itm/Land-Rover-Rang...Swph1dATtr .
Post #525242 18th Aug 2019 11:54am
Weegie
As Stan says, the bit that connects does look a bit too long. I can't remember how mine went but have you tried bolting the unit on first and then manipulating the connection? John
GAP iiD BT
Post #525246 18th Aug 2019 12:28pm
DrRob
JGS 4x4 are a known supplier so I’d trust them over some dodgy trader Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525253 18th Aug 2019 1:48pm
