Home > Technical (L405) > Dynamic Response ECU Reset Help
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
The tune i had installed on my 5.0 SC AB has made the suspension a little firmer which i wasnt too bothered about but its slightly harsh on poor roads and the active roll isnt as effective. If i remove the tune i can feel the body roll is a little tighter and damping more effective so think i should go back but still want the tune.
Speaking to another tuner they said if they found that to be the case with their tune they’d reset the dynamic response ECU, so i think thats what I need to do, anyone know if a simple fuse pull will reset the ECU or is it a software reset only?
Im giving feedback to the tuning co today do will see if they can build that into the handheld device I use to load the tuning file?
Thanks
Carl
Post #524351 10th Aug 2019 7:55am
