![]() | Home > In Car Electronics (L322) > Radio does not turn on |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
I feel your pain here , been driving round without a stereo for months after my 2nd hand replacement unit went the same way as the original |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Oh no. That isn't very reassuring. Did you replace the dsp or the tuner? I haven't taken a look at the tuner yet, it's raining bad again here. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7903 ![]() ![]() ![]() |
The DSP isn’t an amp, it’s just a signal processor and crossover. The BM54 radio is the amp. That’s the silver unit lower down in the boot area, but you prob know where it is.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1557 ![]() ![]() |
Mine does it every so often but then comes good after a vehicle shut down/restart. Ron B. VK2OTC
No dsp at all on the screen. |
My replacement dsp unit finally arrived. Plugged it in and...nothing. not a god damn thing. I shall try disconnecting the battery tomorrow and hopefully that might reset the system somehow. |
It happened again and I found it wasn't off but for some reason the volume was turned right down. I kept my finger on the volume up button on the steering wheel and it slowly increased in volume back to normal. That's happened a couple of times. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
So I've tried a hard reset twice on the car today trying both dsp units and nothing. Tested it's getting a constant power but not switched power. I think the fault is with the radio tuner, the unit with the small 10amp fuse. So I have ordered a replacement and see what happens then. |
An update.
