![]() | Home > Technical (L322) > Found a vacuum pipe hanging .... |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
When I replaced the air intake tube last week I noticed a small bore black U shaped pipe between the two air supply tubes from where they fit onto the airbox. Mine is just hanging there connected to nothing.
A breather pipe if it’s u shaped? 👍 |
It’s hard black plastic and runs up along the air tubes and terminates in a U shape upside down. There is even a moulding on the tube to hold it in place. I assumed it pushed onto something. I thought I might’ve found the restricted performance fault there for a minute! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Thanks Craig. Always learning on this forum! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
