![]() | Home > Maintenance & Mods (L322) > Blower motor intermittent, now stopped working, 2007 TDV8 |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
From the stunned silence I guess this isn't a common issue. Does anybody know if an IID tool is likely to help diagnose the issue?
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
I had similar issues earlier this year, and bought a new FSR, which I fitted, to no avail, the blower still didn't work |
Thanks for the detailled reply. I have tried to spin the fan by hand but can't get to it. I have pulled the pollen filter and got my hand in through the small gap bu can't reach any kind of fan. The cover which holds the pollen filter appears to be held on with three bolts which will tequire the engine or at least engine cover to be removed to get at them. Am I doing this right?
I have an 06 4.4 V8 Petrol, so I'm afraid I don't know if the layout is different on the Diesel cars. Unfortunately, I am at work and the wife has the full fat today, so I can't take a picture to help you - I will do this in the morning, but I'll try to describe my set up, and you may be able to tell if yours is different.
That sounds about the same. I will get the engine cover off and see if I can get at the nuts. Thanks.
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
I have a similar problem. The Blower Motor is only working intermittently. I have already replaced the FSR and today I followed this thread to get to the blowers via the back of the engine Pollen Flier assembly.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 373 ![]() ![]() ![]() |
As above think you can eliminate FSR itself, I had a FSR failure earlier this year that left the fans running constantly even with ignition off, car locked etc. Couldn’t find the relevant fuse and ended up with a totally flat battery.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
I had this problem on my 2011
Hi there,
Harwoods receipt just says
