Home > Maintenance & Mods (L322) > I think I may have solved the restricted performance fault..
Andy
I took the car in for a smoke test yesterday and smoke began to rise from under the engine. The car was sent up in the air on ramps and the undertray were removed and the smoke was coming from the plastic air pipe that goes from the air filter to the turbo on the left side.
There is a hole on the bend that you can get a screwdriver tip in. No idea how a hole has appeared there. The arrow on the pic shows where it is.
I now need to order a new pipe or try and plastic weld this one.
Hoping this will cure the fault. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #522935 27th Jul 2019 5:21am
Andy
And here it is.
Replacement fitted and we will see how she goes 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523664 3rd Aug 2019 10:31am
DrRob
Which garage did you use? Roean? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #523665 3rd Aug 2019 11:11am
Andy
RPM in Birmingham. They have a smoke tester.
I think I may have found another possible leak. When I removed this pipe from the rigid plastic pipe attached to the turbo, I noticed some movement in that pipe where there is a plastic seam. It’s like 2 pipes joined together but you can move it enough to see a gap open up on that seam.
Also I noticed both jubilee clips weren’t tight either.
See below.
Post #523667 3rd Aug 2019 11:44am
Andy
On the pipe I removed, I noticed it was deformed on the one side (opposite side to hole).
Anyone know what might’ve caused this? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523680 3rd Aug 2019 3:24pm
Andy
Update
The fault is still there. I got 140 miles out of the car before it went bong again.
Back to square one! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #524015 7th Aug 2019 6:41pm
DrRob
Perhaps drop it into Tim at Alltrack 4x4 for his thoughts.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #524036 7th Aug 2019 7:42pm
Andy
Im wondering if it might be electrical. It popped up yesterday along a flat dual carriageway whilst cruising and not under any kind of load. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #524902 15th Aug 2019 7:56am
