Home > Maintenance & Mods (L322) > Front suspension stuck in off-road mode “Help” |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
the height sensors may be damaged or bent... ... - .- -.
29th Jul 2019 12:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Check Tail Light
29th Jul 2019 12:58pm |
Bogi 6357 Member Since: 28 Jul 2019 Location: Scottish Borders Posts: 54 |
I will swat up on that this evening and have a look, thank you for the reply |
29th Jul 2019 1:09pm |
Just looks like the standard 2008 Tdv8 rear lights , I will take them out and have a look at the bulbs and see if they have been replaced with an led version Thanks for the reply |
29th Jul 2019 1:11pm |
More likely to be the whole light unit, with new drilled holes for the fixings
29th Jul 2019 6:07pm |
Definitely the pre 2010 ones Joe
29th Jul 2019 9:05pm |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 138 |
If the boost hoses were leaking enough to hear it would normally cause a fault and limp mode. I suspect you have the same problem as me...exhaust manifold(s) leaking due to snapped studs. Cam
30th Jul 2019 9:51pm |
Ahh , is that terminal if not looked at straight away it’s started from a quite whistle and he matured into a decent whistle into my third day of ownership
30th Jul 2019 10:57pm |
If it is indeed the problem it's not terminal at all, it'll just be noisy. It's simply annoying as you want this engine to be nice and quiet. Cam
31st Jul 2019 5:15pm |
Telly Addict , thanks I’ve been nursing the car with anxiety and paranoia just incase it is the turbos or if the exhaust manifold cause the turbos to fail for whatever reason
31st Jul 2019 6:04pm |
