Home > Maintenance & Mods (L322) > MAF Voltage - should they be the same? |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
Given the air flow rate is calculated from the voltage and your air flow rates are similar for both banks then I would ignore the -30V.
28th Jul 2019 10:41am |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
Thanks very much for the reply that's very helpful.
28th Jul 2019 4:09pm |
I would check the fuel trims and see what they are reading.
28th Jul 2019 8:44pm |
Thanks very much that makes sense I hadn’t considered factoring in re-learning.
28th Jul 2019 10:02pm |
These are the fuel trim readings at a cold idle.
29th Jul 2019 11:38am |
