Home > Technical (L322) > Air Con cuts out on prolonged use. |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 |
If your evaporator freezes the A/C is designed to shut off to allow it to defrost and then it should cut back in the system is doing this all the time and that is where the water that drips is coming from, maybe due to the long use it needed to shut off for a bit longer than normal which you wouldn’t normally notice. L322 4.4 TDV8 Current
27th Jul 2019 7:23am |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 196 |
Unnecessary quote removed
27th Jul 2019 2:27pm |
TimperleyRR Member Since: 13 Aug 2016 Location: Manchester Posts: 50 |
Thank ypu
29th Jul 2019 9:04pm |
Charge level was down to a quarter. Been working without issue since (but obviously not been stressed by recent weather). |
17th Nov 2019 12:31pm |
