![]() | Home > Maintenance & Mods (L322) > Injector cleaner for a 2006 4.4 Jaguar Range Rover |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
How long have you owned it?
kirton Member Since: 24 Jan 2014 Location: Crediton Posts: 50 ![]() ![]() ![]() |
I have owned it for about 6 years. I had the LPG system installed, it is BRC.
Valve saver system tries to combat valve seat recession when lpg converted, the jag engine needs it, get a leak down test to confirm whether you have an issue or not.
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
Hi
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Has anyone ever experienced this on a car without lpg? Chaps who have/had the problem what were your fuel trims like? Mine are low on the long term (3 to -3 ) but short term they are up to 20
I put Forte injector cleaner into a half tank of petrol. The engine management light went out after less than 100 miles. Question is, do I still get the injectors cleaned or follow other diagnostics as suggested here?
Is it still bouncing about when on lpg as in your original post you said it was the same on both fuels a tank of treated petrol wouldn't have sorted out the lpg end would it |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
If its misfiring on either fuel I would think it isn't a fueling problem, as lpg will use different injectors to the petrol ones. So your problem should be mechanical (after the fuel system, e.g. valves) or electrical. |
