Home > Maintenance & Mods (L322) > Just Past 100k
SinbadRose
Just Past 100k
Hi Guys,
So have a couple of little things i need to sort like the heated seat issue(should be fine) but now I have just past the 100k mark, what should i be looking at changing/sorting before it fails. It has been serviced each year (gearbox etc at 85k), did the brakes/discs last year, so that should be alright, is it worth doing the turbo pipes that split? anything else that can be done so i can carry on with happy driving?
Cheers
Post #522159 19th Jul 2019 10:14am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I am in the same boat as I am now at 99,000.
Change oil in front and rear diff.
Change oil in transfer box.
Regas and service A/C.
Remove under body protection and wheel arch protectors and hammerite/waxoyl.
Paint brake callipers.
As I have a TD6 I have decided to carry out and oil service every 6 months. At the same time I will also drain down and the refill the gearbox oil.
Jim
Post #522161 19th Jul 2019 10:46am
SinbadRose
trans and diff done 15k ago, calipers done last year when i did the discs, good call on the under side protection, may have a look at that.
Post #522162 19th Jul 2019 10:52am
