Home > Maintenance & Mods (L322) > L322 Front Suspension R&R |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
Took my hubs off todo the ball joints made it much easier and dont tighten the upper arms until you lower the car down with normal weight on the suspension.
15th Jul 2019 7:48pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Maybe you will also need the two torx headed bolts per side that hold the outer ball joints into the hub casting? Not sure if you are planning to remove the whole steering knuckle from the car? You don't have to but getting the rear lower arm ball joints out will be a lot easier I imagine if you do. If the hub comes off you will need a big torque wrench or torque multiplier for the caliper bolts and hub nut. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
15th Jul 2019 10:08pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Rich
16th Jul 2019 12:56am |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
Sure, these are what I ordered. Lower Arm x2 # SKU: RBJ500920 Front Upper Arm RH x1 # SKU: LRO18343 Front Upper Arm LH x1 # SKU: LRO18344 Ball Joint Upper Arm x2 # SKU: RBK500210 Anti Roll Bar Link x2 # SKU: LRO30047 Nuts for Upper and Lower Arms x4 # SKU: RYH501100 Bolts for Upper and Lower Arms x4 # SKU: KYG000043 Flanged Nuts for AntiRoll Bar x4 # SKU: QYH100271 Outer Track Rod Ball Joints x2 # SKU: QJB500050 Inner Rack Tie Rods x2 # SKU: QJB500060 Nuts for Outer Ball Joints x 2 # SKU: QYH500070 We'll see what it looks like when the car is in the air. Not worried about tools as will be in my daughter and son in law's garage. Cheers, Rich |
16th Jul 2019 5:31am |
Thanks Rich, much appreciated.
16th Jul 2019 5:42am |
OK, so all the parts have arrived for the front suspension R&R and I'll have the RR on a lift tomorrow pm.
30th Jul 2019 6:28pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
With all the suspension parts ready to be installed, a new knuckle on each side sure would make life a lot easier. You wouldn't have to bother with loosening all the stuck tapers. They're £300 each though.
31st Jul 2019 5:08am |
Two things; 1 I can't afford to add another £300 per side for new hub assemblies.
31st Jul 2019 8:11am |
All was going well with disassembly until it came to separating the large bottom ball joint from the hub carrier. We didn't bother to split the arm from the ball joint as both we going to be replaced.
3rd Aug 2019 6:35pm |
