Home > Technical (L322) > L322 MY 10. TDV8 gearbox ID tool reading |
sunripe Member Since: 11 Apr 2018 Location: castellon Posts: 9 |
13th Jul 2019 5:18pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Possibly the solenoid for that gear has failed, it is quite common and not too hard to source the service items and fit. |
13th Jul 2019 7:14pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
EDS 1 controls the A clutch and is a ‘yellow cap’ solenoid, so the pressure it feeds to the clutch increases with increasing current. 0.048A is the minimum solenoid current so the A clutch is ‘off’. This applies to gears P, N, R, 5 & 6.
13th Jul 2019 11:41pm |
Thank you very much Phil for the professional response. I just did gearbox maintenance, filter, rubber joints and filter, can be needs more oil?? TY |
14th Jul 2019 10:07am |
14th Jul 2019 10:08am |
Did you follow the correct level-setting procedure (and, in particular, did you have the engine running while you set the level)?
14th Jul 2019 11:10am |
telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 138 |
Great explanation Phil, very informative Cam
15th Jul 2019 9:54am |
27th Jul 2019 8:02pm |
Unfortunately, information on the solenoid currents just before failsafe was triggered doesn’t really tell us anything. What we need to know is what error code has been stored (e.g. P0705, P0734, P0787, etc.) as this explains the reason failsafe was activated.
29th Jul 2019 8:03am |
29th Jul 2019 8:20am |
Sounds like a loss of communication between modules rather than a specific transmission error. Have any electrical connectors been disturbed or disconnected/reconnected recently?
30th Jul 2019 10:35am |
Phil
30th Jul 2019 5:49pm |
