Home > Maintenance & Mods (L322) > Brake Discs TD6 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
a quick look in the WM comes up with this,
9th Jul 2019 4:45pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Thanks Stan , forgot to get the WM out ! Just looking for some decent discs now . As a side note when I had a Volvo XC70 Eurocarparts also sent too small front discs for that so it's not a one off |
9th Jul 2019 4:53pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Try site sponsors Advanced Factors. Got my brake discs and pads from them as a job lot a few years ago and have never had any problems. |
9th Jul 2019 4:56pm |
I purchased a front set from Advanced Factors a few years ago and they did 500 miles and warped , hence the Pagid ones. Just had a quick browse at the AF web site and they list a few more options now so may go with them again |
9th Jul 2019 5:01pm |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 |
I purchased a complete set of front suspension arms from Advanced Factors about 3 years ago. At the MOT in December 2017 I had an advisory that there was wear in the bush in the lower rear arms. Had the same again last December and now they are beginning to knock as well, so going to change them for Powerflex ones. Not good as the car has not even done 20,000 miles on these. |
9th Jul 2019 10:20pm |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
Odd, I fitted the Pagid discs (front) from Euros about 2 years ago and they've been fine TBH 2004 Vogue TD6 - Remapped
10th Jul 2019 12:45pm |
Had a look at another FF in the local super market car park yesterday and , as I suspected , the braking surface of the disc goes from the outside edge down to the hub , unlike the Pagid ones fitted on mine which goes from the outside of the disc to halfway down with a step . As per the attached photo - you can see how the pads overlap the disc ! I have seen it mentioned that the discs on the TD6 are the same at the front as the 4.4 , is anyone able to confirm this please . |
13th Jul 2019 9:45am |
Photo again as it didn't attach first time
13th Jul 2019 9:47am |
The braking system on the TD6 changed to TRW components in 2005, so I wonder if you have the later discs on your 52 plate car. I guess if the pads were wrong, they wouldn't fit in the calipers. |
13th Jul 2019 11:02pm |
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 |
Hi,
17th Jul 2019 3:18pm |
Thanks for that Sandy . Just trying to decide which brand to go with now |
18th Jul 2019 8:14am |
Went with Pagid again and they were delivered 20 minutes after placing the order with EuroCarParts !!! Checked and this time they are the correct ones Used the discount code MID50 and got both for 101.99 (priced individually at 127.99) so happy with the price . |
19th Jul 2019 9:30am |
