Home > Maintenance & Mods (L322) > To clean or not to clean...
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Thoughts people...I have always steered clear of the water meeting electrics conundrum though if looked at in regards to our FFRRs, aren't we supposed to be able to ford the odd stream ?
Post #521116 8th Jul 2019 7:44pm
I wouldn't even do that to my son's 15 year old VW Polo. Just plain lazy to go at it with a pressure washer and snow foam.
If Gunking (don't you just love the smell of Gunk Laughing ), I use a paintbrush with water to rinse it down, or damp cloths
Spray cleaning agent on to your cloth, clean the surface with the cloth, repeat process with plastic/rubber dressing. .
Post #521140 8th Jul 2019 10:05pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
It's not difficult to do it properly.
This took me about an hour to do......and it's no more than 5 mins to keep it looking like this whenever I wash the car.
 Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #521315 10th Jul 2019 7:59am
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Pray tell Bradders.
Post #521588 12th Jul 2019 4:01pm
Bradders
Nothing fancy TBH.
I brushed off all the loose crud first that had accumulated and the gave everything a liberal spray with Auto Finesse Verso, diluted 50/50 but any old all purpose cleaner will do. I wiped the edges along the wings with neat cleaner on an old rag. Left it for 5 mins or so, and I then worked it in everywhere with a detailing brush and then gave it a gentle spray with clean warm water in a small plant sprayer to rinse and worked it in again and gave it a final rinse. Then wiped in down with a microfibre and repeated a couple of times.
I finished off with Autoglym Vinyl and Rubber care sprayed into a microfibre and rubbed that well in. That took a couple of coats too to get and nice and shiny. Thumbs Up Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #521593 12th Jul 2019 4:27pm
I've always cleaned car engine bays with a pressure washer, albeit carefully. Never had any bother at all, that includes petrol.
Just start it when you have finished to allow it to warm up to dry it out.
Do the FFRR once a year. Thumbs Up Smile
Post #521594 12th Jul 2019 5:12pm
Paul thornton
I watched the valeters pressure wash a p38 engine bay at a main dealers once. They didn't want to do it but the salesman insisted.
Fecking thing wouldn't start afterwards!
Post #521596 12th Jul 2019 6:08pm
dazza1983
Don’t be too scared of cleaning b the engine bay.
Use some autoglym engine bay cleaner and abs small brush and use a hose not a pressure washer. Then dress the engine whilst still wet with autoglym Vynil and rubber care. This will make it look new but will also help displace water.
Just don’t get the battery area wet. Everything else is fine.
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #522192 19th Jul 2019 3:07pm
Northern lad
I did mine with just car shampoo, sponge, damp rag and back to black
 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #522360 21st Jul 2019 7:31am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I use WD40 and silicon spray.
Jim
Post #522362 21st Jul 2019 8:12am
rar110
I use a pressure cleaner in the engine bay but only where there’s no wiring. I’m not concerned with overspray or dampness generally.
I also use a microfibre cloth, brushes and silicone, quick detailer or tyre cleaner on other areas. ______________________________
Post #522375 21st Jul 2019 10:58am
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
I know we're told not to use WW40 - as it attracts dust and crap... So what did you use for this amazing, well executed engine bay job? I know this was a few years ago now...but...
Post #610259 24th Oct 2021 5:00pm
JayGee
Will it run better after cleaning? Does it prevent component failure? - if not leave well alone esp with a high pressure hose which can force water into electrical contacts and control modules of which a modern engine bay is densely populated with.
Filthy places engine bays mostly road grime pulled in by the fan / cooling airflow but don’t see it with the bonnet down. 2012 TDV8 Vogue (L322)
Post #610275 24th Oct 2021 6:46pm
mjdronfield
Years ago I visited family on the east coast. Had a 735i at the time. Gunked the engine bay and for some mad reason thought it would be better to hose it off with the engine running…. Big mistake. It back fired and blew the exhaust back box to bits…. That will be £700 for a genuine BMW exhaust Sir…. Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #610282 24th Oct 2021 8:28pm
