![]() | Home > Maintenance & Mods (L322) > Brembo Caliper Pins! |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
A 22mm socket and a breaker bar is what you'll need sir |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
bolts are 21mm 12 point, use some Loctite when reinstalling. if you polish pins and applied some nano coating it will prevent them from sticking. |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 764 ![]() ![]() ![]() |
used copperslip on the pins/retaining pin holes
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1785 ![]() ![]() |
No, copper grease will react with the aluminium caliper, and corrode
use aluminum or nickel paste.
