Home > Maintenance & Mods (L322) > 4.4 tdv8 coolant change
Landyman
Hi everyone I'm new on here so please be gentle 😂 I'm off to the south of France in a few weeks towing the caravan so was thinking it would be a good idea to give the water works some attention before we go. I figured whilst it was drained down it would be prudent to change the thermostat. Has anybody got any helpful tips or hints on the best way to do this and re-fill??
Cheers all 🖒
Post #520560 3rd Jul 2019 8:00pm
Baltic Blue
I have sent you a PM.
Post #520561 3rd Jul 2019 8:29pm
Mover
United Kingdom 2012 Range Rover Westminster TDV8 Java Black
Hi all,
I would also be interested in the coolant change/flush/Bleed procedure on the 4.4 TDV8 (2012 L322 4.4 TDV8)
I can only seem to find info on 3.6 TDV8 or petrol 4.4 v8.
Having just changed the Oil cooler gaskets & 'O' rings I would like to get rid of any oil remaining in system!
Thanks, Dan
Post #520612 4th Jul 2019 9:24am
Baltic Blue
Dan,
I have also sent you a PM.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #520614 4th Jul 2019 9:52am
Mover
Thanks Mike! Thumbs Up
Post #520618 4th Jul 2019 10:31am
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Also trying to find a procedure for bleeding air out of the coolant. Is the process detailed anywhere?
Post #537662 16th Dec 2019 5:53pm
should be in the WM which a link is in the wiki... ... - .- -.
Post #537664 16th Dec 2019 5:55pm
M@r]{
Had a look and can't see one for the 4.4 TDV8? (I'm now reverting to searching on youtube Smile )
Post #537667 16th Dec 2019 5:57pm
https://drive.google.com/drive/folders/0By...VZTRGYwSmc ... - .- -.
Post #537669 16th Dec 2019 6:00pm
M@r]{
Now that is fantastic!! A workshop manual! Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #537676 16th Dec 2019 6:24pm
