Home > General > facelift or not?
Careeraxe
2018 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
facelift or not?
Hi there folks
I have seen a RR that I like.
How do I check if it is the facelift version? It has the newer lights and touch screen nav.
It was registered in May 2005. The logbook states it as a RR TD6 vogue SE A.
Many thanks! Smile
Post #52008 27th Feb 2011 2:38pm
Fox
Look at the 10th digit on the VIN/chassis number.
You want a 6 for a 2006 model, which had the full facelift and modifications.
Post #52018 27th Feb 2011 3:34pm
Careeraxe
Thanks!
It does contain a '6'. Most helpful to know!
Post #52021 27th Feb 2011 3:50pm
Careeraxe
Hi
Just thought it is a 2005 car. Should it still have a 6?
Perhaps a stupid question?
Post #52050 27th Feb 2011 6:28pm
bozmandb9
I think the 2006 model which Fox was referring to was 2006 MY (model year), which could have been registered from March 2005. The visible parts of the facelift are basically the lights and the navigation system, so it's pretty certain yours is a facelift, particularly since the vin matches too.
But it all depends on what you're talking about when you say facelift. The was a number of interior improvements made in the 2007 MY, which some people would call a facelift, and which makes a car generally more desirable. This is easy to spot because there is a distinct lack of handbrake lever (becomes electronic), and you get the terrain response dial. Range Rover-less at the moment - Pining!
Post #52053 27th Feb 2011 6:36pm
Surely if you mean the 2006MY facelift then you may also want to ensure you have the re-designed grille & front bumper curving around the headlights plus the revised rear light clusters and the touch screen nav as well as a Jag engine instead of a BMW in the petrol models!!!
And remember some Non Facelift 2005MY come with touch screen nav and fibre optics. Thumbs Up
Post #52056 27th Feb 2011 6:57pm
Fox
If it's got the 6 in the VIN number it will have the facelifted bumper and headlights, the touch screen and all the other stuff such as the improved front differential as they realised there was a problem there. This is commonly refered to as the facelift model launched in 2005 as the 2006 model spec, as it looked like it'd had a "facelift".
Facelift meaning it looks different.
So it won't have the interior improvements from the 2007 model, no terrain response or TDV8 engine. Which I'm sure makes sense as you've said it's a 2006 model. Just make sure the 6 is the 10th digit of the VIN number.
Post #52072 27th Feb 2011 9:25pm
dubbs
United Kingdom 2007 Range Rover Vogue SE Supercharged Buckingham Blue
Does that mean I've got to stop call them a half-facelift Fox?? Wink
Post #52141 28th Feb 2011 2:46pm
Careeraxe
Its all very confusing! 2005 but the 2006 MY facelift! Exclamation
I would like the terrain response (post 2007) but it seems that cars are over 28k in this bracket. Unable to justify spending so much at the moment.
Just a further question: the rr that I saw had a button that would increase/decreases the height of the car. Is this standard on all models of the vogue? It was not on another range that I saw so seem confused now? [Not sure of the exact name Embarassed ]
Anyway back to the drawing board....
Post #52247 28th Feb 2011 10:15pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Pretty sure they all got the air suspension as standard.. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #52250 28th Feb 2011 10:19pm
bozmandb9
I think it's just that the buttons are in different positions. On the older models there's a big round thing on the centre console, on the later cars you get buttons near the terrain response controls. For certain they all have the adjustable air suspension. Range Rover-less at the moment - Pining!
Post #52251 28th Feb 2011 10:31pm
dubbs
You can have mine if you do stretch to 28k Thumbs Up
Post #52256 28th Feb 2011 10:44pm
Careeraxe
Bow down
Thanks folks!
Perhaps I could increase my budget to find a 2007MY with the newer updated interior...
Post #52257 28th Feb 2011 10:45pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Just to be clear Gaz , do you mean the Petrol goes to Jag rather than BWM? I understood the TD6 was only ever BMW but I'm doubting myself now Confused 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #52303 1st Mar 2011 12:20pm
Martin
Site Admin
The Jag V8 (in NA and SC forms) replaced the BMW V8 Petrol, the TDV8 replaced the BMW Td6
Post #52306 1st Mar 2011 12:54pm
